Can't rotate family (RCP Shrub) in plan
2 ANTWORTEN 2
Nachricht 1 von 3
sascari
164 Aufrufe, 2 Antworten
I added two detail elements to the standard RCP shrub family (they are intended to represent uplights). But when I try to rotate the family in plan nothing happens. I've tried disabling things such as "Always Vertical" but it doesn't change anything.
EDIT: Oddly enough the align tool seems to be able to change its rotation. However, it's very cumbersome doing it through the align tool and the rotate tool would be preferable.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: sascari
Post the family.
Nachricht 3 von 3
Did you chance make the family Work Planed-Based and not Always Vertical and then place it on a Face or Work Plane in the Project that is not co-planar to the Plan View?   That would cause issue you described.
Go to 3D Top View, Set the Current Work Plane to the Face by Pick a Plane Method and choosing the Face.  Now try rotating.
Any luck?
