I am unable to rotate the Tote Bin from the side views.
I would like to align it to the reference plane Rotational RP, which I'd like to use to rotate using a parameter.
Please see attached.
Thanks in advance,
Connor
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
@Anonymous
I have reviewed your attached family and I'm also face this type of problem in past.
Please use Face base or Line base family if you want to rotate family in elevation or section view.
Please find the attached sample line base family for your reference.
RJ
I saw the neatest video from AU where the guy was hosting family parts to revolved objects and controlling the angle of revolution with parameters, and controlling the visibility of the revolved object.
@ToanDN yes, its quite easy once you know how (I didn't know about the workplane dropdown/
@Anonymous thanks, but changing the type of family didn't seem to play an important role.
@Bob_Zurunkle video link for solution!
So, to summarise for others who may have the same issue:
1. Go to Family Category & Parameters at the top left, then:
2. Save & load into workplane based family:
Thereafter you can rotate the host plane to rotate the family.
