Can't Remove a Void
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
PhilvK
1674 Aufrufe, 6 Antworten
Can't Remove a Void
I created a void extrusion and used it in a wall to get an angled end at the wall. I now want to remove the void but can't find it, or a way to remove it. Using Uncut doesn't seem to work either as the void form is either gone or terminally invisible!
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: PhilvK
Tabbing on that angle of the wall created by that void won't work?
Nachricht 3 von 7
PhilvK
als Antwort auf: ToanDN
Correct, I can't find the void by tabbing.
Nachricht 4 von 7
RDAOU
@PhilvK
Cut and paste back same place should remove an in-place void (See Gif 1)
Alternatively you could use phase filter to reveal demo (See Gif 2)...this makes it easier to
  • either select the void
  • or SELECT the demo portion and delete it...This will automatically delete the Void cut
Nachricht 5 von 7
PhilvK
I copy clipped into a new project and can now see it. I'll just redo the wall.
Nachricht 6 von 7
RDAOU
@PhilvK
You tried the above and didn't work too!!!
Nachricht 7 von 7
PhilvK
als Antwort auf: RDAOU
Cut and paste it back in place worked. Thank you!
