Revit 2023 won't let me "Hide Column" in schedule.
Only happens with the column furthest to the left, for some reason.
See screenshots below of Revit 2022.1 and Revit 2023.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Is that a column in the Parent Schedule next to a column in an Embedded Schedule?
@LicensedARCH wrote:
Don’t know - have no idea what that means…
An "Embedded Schedule" is a Schedule that is embedded into another.
My thinking is that it may have something to do with Embedded Schedule. Maybe the Separator character used? Dunno. Just troubleshooting here with the limited information you've provided. All I can say for sure, is that I can't replicate that behavior/issue.
Might help if you post your "bad" file here so we can test.
All I know is: I was able to do it on 2022 but not on 2023.
I’m reverting to 2022.
2023 also mirrored the text on some keynotes.
It really messed me up - whole day wasted…
Don’t want to find out any more issues
Yeah I only start a working project on a new version AFTER at least one service pack.
Here is a file with the schedule.
Sorry it took so long...
I downloaded this from a post so it might have gotten corrupted...
Let me know if you can get the first column on the left to unhide and then hide again in 2023.
I removed 2023 from my computer.
Will see if I can update once there is a service pack.
For now, go to Formatting tab and hide/unhide it until Autodesk issues a fix.
Or, simply move the column so it is not the first one to the left then you can Hide it via right click menu or ribbon.
