I created a sloped wall by face using the face of a mass. Now it is only possible to place windows on the left side of the wall. When placing windows on the right side I get the error 'Can't cut instance of 0400 x 1200mm out of Wall.' Any ideas??? (I have attached the model)
Gelöst! Gehe zur Lösung
Gelöst von Revit_Whisperer. Gehe zur Lösung
It seems to work better with a face based family (I left it as a generic model). I attached the FB object. I did the window x's as a new subcategory of Generic Model in the family, that can be turned off in the views you don't want to see it in like a 3d view.
Thanks it works now! In fact your model actually inspired me to develop the design of the envelope even further and create a water bubble aesthetic which suits the project very well as the building is a water sports centre, located on the edge of a riverbank.
Thanks a great bunch!!!
