Can't place railing on Spiral stair
5 ANTWORTEN 5
Nachricht 1 von 6
sameerkhankhattak
630 Aufrufe, 5 Antworten
Hi. when I try to place railing on spiral stair (which i've already made), the railing placed are all over the place and not where it should be. Whats the reason and how to fix this? (please see screenshots)
5 ANTWORTEN 5
Nachricht 2 von 6
RDAOU
als Antwort auf: sameerkhankhattak
@sameerkhankhattak
I am cannot recreate the issue you are having there.. Did you use automatic railing or are you placing the railing separately?
Maybe you can upload the file?
Nachricht 3 von 6
Your inside diameter is too small for a rail.
Nachricht 4 von 6
sameerkhankhattak
als Antwort auf: barthbradley
Thanks for the reply. I need the same diameter stair. What is the solution. And yes, I'm placing the railing seperately on the host
Nachricht 5 von 6
RDAOU
@sameerkhankhattak you are not giving us much to work with...attach your Revit file so one may have a look at the stair and rail settings you have there
Nachricht 6 von 6
The solution would be not to use a rail on the inside -- pretty much like the traditional spiral.
