Can't pick stairs
3 ANTWORTEN 3
Nachricht 1 von 4
dilistan.bozan
232 Aufrufe, 3 Antworten
Can't pick stairs
When i try to put srair path, i cannot select stairs. These staird are not sketch-based. How can i solve it?
3 ANTWORTEN 3
Nachricht 2 von 4
jay_colcombe
als Antwort auf: dilistan.bozan
If there is already a Stair Path indicated it will not allow selection!  Is there a Symbol out of View?
Delete, and it sill allow placement/selection
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 4
dilistan.bozan
als Antwort auf: jay_colcombe
Hi thankx for reply. Nope, there is no path
Nachricht 4 von 4
jay_colcombe
I have only seen this with Stairs by Sketch, can you share?
The only other limitation is a Detail View but Stair Path is greyed out so self explanatory.
If it is hidden, try drawing a plan region in the view and edit/set your view range setting and see if helps?
Jay Colcombe
