Can't pick stairs
Can't pick stairs
dilistan.bozan
Can't pick stairs
dilistan.bozan
When i try to put srair path, i cannot select stairs. These staird are not sketch-based. How can i solve it?
jay_colcombe
If there is already a Stair Path indicated it will not allow selection!  Is there a Symbol out of View?
Delete, and it sill allow placement/selection
Jay Colcombe
Autodesk Certified Instructor
dilistan.bozan
Hi thankx for reply. Nope, there is no path
jay_colcombe
I have only seen this with Stairs by Sketch, can you share?
The only other limitation is a Detail View but Stair Path is greyed out so self explanatory.
If it is hidden, try drawing a plan region in the view and edit/set your view range setting and see if helps?
Jay Colcombe
