Hello. Revit 2023 isnt working for me, it instantly crashes even after a clean install..
I dont know why, bellow is the error codes:
' 0:< Initial VM: Avail 134213370 MB, Used 18 MB, Peak 18; RAM: Avail 24053 MB, Used 38 MB, Peak 18
' 0:< GUI Resource Usage GDI: Avail 10000, Used 0, User: Used 1
'C 04-May-2023 15:28:09.364; ->UI-less InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Metric Library=C:\REVIT\Libraries\English\ (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -12 -> 134213359 MB, Used +2 -> 21 MB, Peak +2 -> 21 MB; RAM: Avail -34 -> 24019 MB, Used +5 -> 43 MB, Peak +5 -> 43 MB
' 0.619345 1:<<<wait for ForgeUnitsAdapter::configureFolders
' 0:< ::0:: Delta VM: Avail -10 -> 134213349 MB, Used +0 -> 22 MB, Peak +0 -> 22 MB; RAM: Avail -74 -> 23946 MB, Used +2 -> 46 MB, Peak +2 -> 46 MB
' 0:< GUI Resource Usage GDI: Avail 10000, Used 0, User: Used 2
'C 04-May-2023 15:28:10.366; ->loadAllDB (this=000002B6C7E5D0B0)
' 0:< ::0:: Delta VM: Avail -176 -> 134213173 MB, Used +15 -> 37 MB, Peak +15 -> 37 MB; RAM: Avail -31 -> 23915 MB, Used +58 -> 105 MB, Peak +58 -> 105 MB
'C 04-May-2023 15:28:10.539; <-loadAllDB (this=000002B6C7E5D0B0)
' 0:< ::0:: Delta VM: Avail -2 -> 134213172 MB, Used +2 -> 40 MB, Peak +2 -> 40 MB; RAM: Avail -68 -> 23848 MB, Used +5 -> 110 MB, Peak +5 -> 110 MB
' 0:< SystemSettings:
' 0:< 12=multiCoreCharacteristic
' 0:< true=isDotNetInstalled
' 0:< 4.8.09032(533320)=dotNetInstalledVersionString
' 0:< false=isProcessUserModeExceptionPolicyDisabledForCallbackFilter
' 0:< ::0:: Delta VM: Avail -123 -> 134213049 MB, Used +14 -> 54 MB, Peak +14 -> 54 MB; RAM: Avail -77 -> 23771 MB, Used +24 -> 135 MB, Peak +24 -> 135 MB
' 0:< GUI Resource Usage GDI: Avail 9989, Used 11, User: Used 9
' 0:< Autodesk Revit 2023
' 0:< 64-bit load point = C:\REVIT\Revit 2023
' 0:< this journal = C:\Users\jona5\AppData\Local\Autodesk\Revit\Autodesk Revit 2023\Journals\journal.0005.worker1.log
'C 04-May-2023 15:28:11.313; Journal Init
'C 04-May-2023 15:28:11.313; 0:< Log Summary
' 0:< .Marshalling
' 0:< ...CompactCaching = 1 (Enabled)
' 0:< .ThreadPool
' 0:< ...ActivePoolSize = 51
' 0:< ...ConfiguredPoolSize = automatic
' 0:< ...ParallelCores = 12
' 0:< ...RequestedPoolSize = automatic
' 0:< .Tuning
' 0:< ...ElemTable = 1 (Serial except when multithreaded)
'C 04-May-2023 15:28:11.313; BC: 0,0,0
' 0:< API_SUCCESS { Registered an external service: Name(DirectContext3D Service); VendorId(ADSK); ServiceId(e454a471-b9f3-4cb7-96b1-bab4cf7742a6) }
' 0:< API_SUCCESS { Registered an external service: Name(External Data Type Service); VendorId(ADSK); ServiceId(e05a890c-311f-47e5-9652-ebfb7da7663c) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource Service); VendorId(ADSK); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Registered an external service: Name(External Data Type Service); VendorId(ADSK); ServiceId(8b40f7b3-625b-4e63-8f95-0252f3c488ff) }
' 0:< API_SUCCESS { Registered an external service: Name(Generic Repository Helper Service); VendorId(ADSK); ServiceId(cf24951a-62aa-4c7c-a26a-cdb1379b3649) }
' 0:< API_SUCCESS { Registered an external service: Name(AXM Importer Service); VendorId(ADSK); ServiceId(af2183c2-e854-41cf-85bb-fe0675f12181) }
' 0:< API_SUCCESS { Registered an external service: Name(NavisworksExportService); VendorId(ADSK); ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2) }
' 0:< API_SUCCESS { Registered an external service: Name(External Parameter Service); VendorId(ADSK); ServiceId(0d4ef84e-987b-4106-9a53-2b460ec38abc) }
' 0:< API_SUCCESS { Registered an external service: Name(EntitlementExternalService); VendorId(ADSK); ServiceId(9111ab07-9bd9-4b68-a01f-c0a0dcae1564) }
' 0:< API_SUCCESS { Registered an external service: Name(ModelAccessValidationService); VendorId(ADSK); ServiceId(584ac31c-5e21-4892-95b5-382680d021bf) }
' 0:< API_SUCCESS { Registered an external service: Name(CloudExternalService); VendorId(ADSK); ServiceId(279080e0-8c45-44eb-9027-d4eb37ece90d) }
' 0:< API_SUCCESS { Registered an external service: Name(Infrastructure Alignment Information Service.); VendorId(ADSK); ServiceId(7ca4bc09-66de-4fed-93db-5c8e02874e9d) }
' 0:< API_SUCCESS { Registered an external service: Name(ExternalDataManagerService); VendorId(ADSK); ServiceId(f036684f-7c8a-4f51-88aa-12dee1414d7b) }
' 0:< API_SUCCESS { Registered an external server: Name(TestServer); VendorId(ADSK); ServerId(b9ac22ad-3594-4bf8-94a1-d14651d5b4be); ServiceId(f036684f-7c8a-4f51-88aa-12dee1414d7b) }
' 0:< API_SUCCESS { Registered an external service: Name(Code Checking Parameter Service); VendorId(ADSK); ServiceId(de6db8de-dea6-40bd-9503-4ffe62ff6143) }
' 0:< API_SUCCESS { Registered an external service: Name(Hole Definition Service); VendorId(ADSK); ServiceId(9d39d4fe-6e5f-4088-8655-b349d00e864a) }
' 0:< API_SUCCESS { Registered an external service: Name(Modify Connection Ranges of applicability Service); VendorId(ADSK); ServiceId(f04d2d31-5d7d-4ec0-8a2b-c52fbd6d83c5) }
' 0:< API_SUCCESS { Registered an external service: Name(FramingProfileService); VendorId(ADSK); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Registered an external service: Name(Modify Connection Parameters Service); VendorId(ADSK); ServiceId(e9c0f948-320e-4e7f-a573-10755555305d) }
' 0:< API_SUCCESS { Registered an external service: Name(Connection Type Changed Service); VendorId(ADSK); ServiceId(e31c3100-9cab-4303-b85b-4171703ce1c4) }
' 0:< API_SUCCESS { Registered an external service: Name(Section Type Parameter Service); VendorId(ADSK); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Registered an external service: Name(Site Insert Service); VendorId(ADSK); ServiceId(c9979a42-11ab-4c25-93e1-abfb50b7be60) }
' 0:< API_SUCCESS { Registered an external service: Name(RebarUpdateService); VendorId(ADSK); ServiceId(a2c22b44-c231-4d3f-b653-b81b6f8be150) }
' 0:< API_SUCCESS { Registered an external service: Name(Path of travel calculator); VendorId(ADSK); ServiceId(ee502325-58ce-4d6e-9a2c-643608b1fbd9) }
' 0:< API_SUCCESS { Registered an external service: Name(Internal Forces Service); VendorId(ADSK); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Registered an external service: Name(ATF Service); VendorId(ADSK); ServiceId(bb3a96c9-e04a-40e4-8ecf-1464dd6aa7eb) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Pressure Drop Calculator); VendorId(ADSK); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Pressure Drop Calculator); VendorId(ADSK); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external service: Name(Plumbing Flow Calculator); VendorId(ADSK); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Export Service); VendorId(ADSK); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Exporter); VendorId(ADSK); ServerId(ef8d0493-7f36-42b5-b9aa-8aaac716482b); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Import Service); VendorId(ADSK); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Importer); VendorId(ADSK); ServerId(660a7370-f6d6-43c8-8456-6b2eea785110); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
'C 04-May-2023 15:28:11.318; 0:< manage debug modes
'C 04-May-2023 15:28:11.318; 0:< MFCApp::testGraphicsHardware
' 0:< Revit Graphics Information
' 0:< Current Mode : DirectX Hardware
' 0:< Use Hardware: ON
' 0:< Use Overlays : ON
' 0:< START updateCanUseHardware
' 1:< ::0:: Delta VM: Avail +44 -> 134213094 MB, Used +2 -> 57 MB, Peak +14 -> 69 MB; RAM: Avail -174 -> 23598 MB, Used +3 -> 138 MB, Peak +7 -> 142 MB
' 1:< GUI Resource Usage GDI: Avail 9989, Used 11, User: Used 9
' 1:<
'OGS Device Memory Size: 20199 MB
' 1:< ::0:: Delta VM: Avail -342 -> 134212753 MB, Used +161 -> 219 MB, Peak +151 -> 220 MB; RAM: Avail -35 -> 23563 MB, Used +32 -> 170 MB, Peak +29 -> 171 MB
' 1:< GUI Resource Usage GDI: Avail 9989, Used 11, User: Used 11
' 1:< DX Device: DirectX 11, Hardware
' 1:< DX Device: DirectX 11, WARP
'C 04-May-2023 15:28:15.944; 1:< START video card certification
' 1:<
'Current driver version: 31.0.15.2879
'Certified driver(s):
' 1:< VIDEO CARD ENVIRONMENT: CARD="NVIDIA GeForce GTX 1650" ManufacturerID="10DE" DeviceID="1F91" osID="8000" DRIVER="31.0.15.2879" DEVICE="DX11" FL_Caps="50" (Shader Model)
'C 04-May-2023 15:28:15.998; 1:< FINISH video card certification
' 4.680186 1:<<<updateCanUseHardware
' 0:<
'Can use hardware=y
'Hardware support flags:
'DrvOlderThanTested=n
'DrvNewerThanTested=n
'CardIsNotListed=y
'NotCertifiedEnv=n
'SoftwareModeForced=n
' 0:< FINISH CanUseHardware(forced)
'C 04-May-2023 15:28:15.998; 0:< MFCApp::testMSAA
'C 04-May-2023 15:28:15.998; <-UI-less InitNativeInstance
'C 04-May-2023 15:28:15.998; ->UI-less InitManagedInstance
' 0:< ::0:: Delta VM: Avail -591 -> 134212162 MB, Used +48 -> 267 MB, Peak +46 -> 267 MB; RAM: Avail +55 -> 23619 MB, Used +52 -> 223 MB, Peak +51 -> 223 MB
' 0:< GUI Resource Usage GDI: Avail 9989, Used 11, User: Used 12
' 0:< To make IFC server work.
' 0:< ::0:: Delta VM: Avail -179 -> 134211984 MB, Used +50 -> 317 MB, Peak +51 -> 318 MB; RAM: Avail -375 -> 23245 MB, Used +77 -> 301 MB, Peak +78 -> 302 MB
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application ATF Translation Server (fa3d130b-2b6b-45be-8734-67536086143f). }
' 0:< API_SUCCESS { Starting External DB Application: ATF Translation Server, Class: ATFTranslationServer.ATFTranslationServerRegister, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\REVIT\Revit 2023\AddIns\ATFTranslationServer\Autodesk.ATFTranslationServer.DBApplication.dll, Assembly Version: 23.1.10.4 }
' 0:< Third Party Updater 'AlignmentsDB: Update or delete alignment station labels.' registered for all documents.
' 0:< Third Party Updater 'AlignmentsDB: Update alignment depending on units.' registered for all documents.
' 0:< ::0:: Delta VM: Avail 134211984 MB, Used 317 MB; RAM: Avail -15 -> 23230 MB, Used +3 -> 304 MB, Peak +3 -> 305 MB
' 0:< API_SUCCESS { Registered an external server: Name(AecAlignment Server); VendorId(ADSK); ServerId(0558397d-5761-4a0d-8883-42a166446d81); ServiceId(7ca4bc09-66de-4fed-93db-5c8e02874e9d) }
' 0:< API_SUCCESS { Starting External DB Application: AlignmentsDB, Class: Autodesk.Revit.DB.Infrastructure.AlignmentsDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\REVIT\Revit 2023\AddIns\CivilAlignments\Autodesk.CivilAlignments.DBApplication.dll, Assembly Version: 23.1.10.4 }
' 0:< ExternalDBApplication Autodesk.CoordinationModelDB.CoordinationModelDBApplication (C:\REVIT\Revit 2023\AddIns\CoordinationModel\Autodesk.CoordinationModelDB.dll) was not loaded in RevitWorker
' 0:< ExternalDBApplication EntitlementDB.EntitlementDBApplication (C:\REVIT\Revit 2023\AddIns\ModelBrowser\Autodesk.Entitlement.Utilities.dll) was not loaded in RevitWorker
' 0:< ExternalDBApplication Autodesk.LightboxDB.Main (C:\REVIT\Revit 2023\AddIns\Lightbox\Autodesk.LightboxDB.dll) was not loaded in RevitWorker
' 0:< ExternalDBApplication SiteLinker.SiteServerApp (C:\REVIT\Revit 2023\AddIns\SiteLinker\Autodesk.LinkTopography.Parser.dll) was not loaded in RevitWorker
' 0:< ExternalDBApplication Autodesk.Revit.DB.ResultsBuilder.ResultsBuilderApplication (C:\REVIT\Revit 2023\AddIns\ResultsManagerExplorer\Autodesk.ResultsBuilder.DBApplication.dll) was not loaded in RevitWorker
' 0:< API_SUCCESS { Registering DocumentClosing event by application Route Analysis (40e082fd-2661-4bbb-83f0-e960745a72a2). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Route Analysis (40e082fd-2661-4bbb-83f0-e960745a72a2). }
' 0:< API_SUCCESS { Registered an external server: Name(Simulex (tm) Calculation); VendorId(ADSK); ServerId(3ac50ffe-852f-4a77-941f-851ddfbcbd57); ServiceId(ee502325-58ce-4d6e-9a2c-643608b1fbd9) }
' 0:< API_SUCCESS { Starting External DB Application: Route Analysis, Class: RouteAnalysisDB.RouteAnalysisDBApplication, Vendor : ADSK(https://knowledge.autodesk.com/search?p=REVITPRODUCTS&search=Path%20of%20Travel&sort=score&page=1&kn...), Assembly: C:\REVIT\Revit 2023\AddIns\RouteAnalysis\Autodesk.RouteAnalysis.DBApplication.dll, Assembly Version: 23.1.10.4 }
' 0:< ::0:: Delta VM: Avail -3 -> 134211981 MB, Used +1 -> 319 MB, Peak +2 -> 321 MB; RAM: Avail -22 -> 23209 MB, Used +5 -> 310 MB, Peak +6 -> 312 MB
' 0:< API_SUCCESS { Registering DocumentCreating event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentOpening event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering LinkedResourceOpened event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering LinkedResourceOpening event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< Third Party Updater 'Steel Connections DB extension: Steel Fabrication Updater' registered for all documents.
' 0:< ::0:: Delta VM: Avail -75 -> 134211907 MB, Used +9 -> 329 MB, Peak +8 -> 329 MB; RAM: Avail -69 -> 23141 MB, Used +19 -> 330 MB, Peak +18 -> 330 MB
'C 04-May-2023 15:28:33.963; 0:< Checking SQL instance SteelConnections2023 health...
' 0:< ::0:: Delta VM: Avail 134211907 MB, Used 329 MB; RAM: Avail -285 -> 22856 MB, Used 330 MB
'C 04-May-2023 15:28:35.093; 0:< Testing connection to Steel Connections databases...
' 0:< ::0:: Delta VM: Avail -237 -> 134211670 MB, Used +61 -> 391 MB, Peak +62 -> 391 MB; RAM: Avail -112 -> 22744 MB, Used +109 -> 440 MB, Peak +109 -> 440 MB
' 0:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 13
' 0:< API_SUCCESS { Starting External DB Application: Steel Connections DB extension, Class: Autodesk.SteelConnectionsDB.Main, Vendor : ADSK(https://knowledge.autodesk.com/search?search=detailed%20steel%20modeling&p=REVITPRODUCTS&sort=score), Assembly: C:\REVIT\Revit 2023\AddIns\SteelConnections\Autodesk.SteelConnectionsDB.dll, Assembly Version: 23.1.10.4 }
' 0:< ExternalDBApplication Autodesk.Revit.DB.StructuralRibbon.Application (C:\REVIT\Revit 2023\AddIns\ResultsManagerExplorer\Autodesk.StructuralRibbon.Application.dll) was not loaded in RevitWorker
' 0:< ExternalDBApplication ConnectedDesktopDB.ServerApp (C:\REVIT\Revit 2023\AddIns\ConnectedDesktop\ConnectedDesktopDB.dll) was not loaded in RevitWorker
' 0:< ExternalDBApplication KeynoteDBServer.ServerApp (C:\REVIT\Revit 2023\AddIns\Keynote\KeynoteDBServer.dll) was not loaded in RevitWorker
' 0:< API_SUCCESS { Registered an external server: Name(Plumbing Fixture Flow); VendorId(ADSK); ServerId(56121d7d-e1d7-42a3-bed8-f4d1d32058c8); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external server: Name(Altshul-Tsal Equation); VendorId(ADSK); ServerId(042a10e0-8d24-46a4-9596-d192b3125d0c); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(2e9a77c0-62a0-4693-9442-33312be60ad7); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(58ea1b7c-2fca-453f-9ab9-7a3b9927ecc1); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(e395a0ec-48a4-4255-b957-afbb3d73cb67); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(0875f550-6141-4e34-a6b7-547cf9cfda01); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Starting External DB Application: Straight Segment Pressure Drop Servers, Class: StraightSegmentCalculationServers.ServerApp, Vendor : ADSK(https://knowledge.autodesk.com/search?p=REVITPRODUCTS&search=Pipe%20Pressure%20Drop&sort=score&page=...), Assembly: C:\REVIT\Revit 2023\AddIns\MEPCalculation\Autodesk.MEP.SegmentCalculation.DBApplication.dll, Assembly Version: 23.1.10.4 }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(76eff5da-2e71-45f7-b940-cc5716328ba0); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Coefficient from ASHRAE Table); VendorId(ADSK); ServerId(8baf7d75-8b9b-46d0-b8ce-3ad1c19e6b19); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(5a598293-1504-46cc-a9c0-de55c82848b9); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(46245996-eebb-4536-ac17-9c1cd917d8cf); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(61e7b8e1-16d1-4fe4-82f0-327af736323f); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(K Coefficient from Table); VendorId(ADSK); ServerId(51dd5e98-a9dd-464b-b286-4a37953610bf); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(32d58662-b467-4f7b-b728-f6ad7b7ba5e3); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(16f4f7be-0ac0-461d-a9a4-1d3511cd280e); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Starting External DB Application: Fitting And Accessory Pressure Drop Servers, Class: FittingAndAccessoryCalculationServers.ServerApp, Vendor : ADSK(https://knowledge.autodesk.com/search?p=REVITPRODUCTS&search=Fitting%20Pressure%20Loss&sort=score&pa...), Assembly: C:\REVIT\Revit 2023\AddIns\MEPCalculation\Autodesk.MEP.FittingCalculation.DBApplication.dll, Assembly Version: 23.1.10.4 }
' 0:< ExternalDBApplication Autodesk.Revit.UI.Collaborate.CollaborateDBApplication (C:\REVIT\Cloud Models for Revit 2023\CollaborateDB.dll) was not loaded in RevitWorker
' 0:< ExternalDBApplication AXMImporterWrapper.AXMImporterApp (C:\REVIT\FormIt Converter for Revit 2023\AXMImporter.dll) was not loaded in RevitWorker
' 1:< ::0:: Delta VM: Avail -2 -> 134211669 MB, Used 391 MB, Peak +2 -> 394 MB; RAM: Avail -58 -> 22687 MB, Used +1 -> 441 MB, Peak +3 -> 443 MB
' 1:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 13
' 1:< API_SUCCESS { Registered an external server: Name(ATFTranslationServer); VendorId(ADSK); ServerId(252f643e-9927-4c06-a704-4a8b3587b979); ServiceId(bb3a96c9-e04a-40e4-8ecf-1464dd6aa7eb) }
'C 04-May-2023 15:28:51.512; <-UI-less InitManagedInstance
'C 04-May-2023 15:28:51.512; 0:< RevitWorker.exe 1
'C 04-May-2023 15:28:51.513; ->UI-less ExitManagedInstance
' 0:< Third Party Updater 'Steel Connections DB extension: Steel Fabrication Updater' has been unregistered.
' 0:< API_SUCCESS { Unregistering DocumentCreating event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentCreated event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentOpening event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< ::0:: Delta VM: Avail 134211669 MB, Used +0 -> 392 MB; RAM: Avail +34 -> 22721 MB, Used +0 -> 442 MB
' 0:< API_SUCCESS { Unregistering DocumentOpened event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentSaving event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentSavingAs event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentSaved event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentSavedAs event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentChanged event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering LinkedResourceOpened event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering LinkedResourceOpening event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentSynchronizingWithCentral event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentSynchronizedWithCentral event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< ::0:: Delta VM: Avail +17 -> 134211687 MB, Used -4 -> 388 MB; RAM: Avail +70 -> 22791 MB, Used -8 -> 434 MB
' 0:< Forcibly unregistering Updater with id:c94154ad-4bbe-4682-a816-73cc79e2a9d0
' 0:< Forcibly unregistering Updater with id:5a37bca6-58d6-44b0-bf9a-5da8ee33a464
' 0:< Forcibly removing all update triggers for all Updaters
' 0:< Unregistering all external services.
'C 04-May-2023 15:28:52.069; <-UI-less ExitManagedInstance
'C 04-May-2023 15:28:52.069; ->UI-less ExitNativeInstance
' 0:< ::0:: Delta VM: Avail +200 -> 134211887 MB, Used -145 -> 243 MB; RAM: Avail +10 -> 22801 MB, Used -10 -> 425 MB
' 0:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 12
'C 04-May-2023 15:28:52.117; Journal Exit
'C 04-May-2023 15:28:52.117; BC: 0,0,0
' 0:< FormOrAbandon exec= 1 (parallel= 0) self= 0.000097 sec (avg= 0.000)
' 0:< InstrumentationTask exec= 1 (parallel= 1)
' 0:< TaskFileExists exec= 341 (parallel= 334)
' 0:< ::0:: Delta VM: Avail +48 -> 134211935 MB, Used -5 -> 238 MB; RAM: Avail +15 -> 22817 MB, Used -15 -> 411 MB
' 0:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 11
'C 04-May-2023 15:28:52.199; <-UI-less ExitNativeInstance
Can you provide your system information here, mainly total/free disk space? Do you have any other versions of Revit installed? The video card is fairly recent but I would go to nVidia's site and make sure you have the latest graphics drivers.
If you have the Steel Connections add-in installed, let's also remove that one for now, it may also be causing an issue.
thanks - David B.
David A. Butts
Virtual Design and Construction Manager - Kimley-Horn
Revit Certified Professional/Autodesk Certified Instructor
Revit, AutoCAD Architecture, MEP, Plant 3D, BIM Collaborate Pro Subject Matter Expert
I too am having issues with
What is on is that this is on machines with both Advance steel extenstion added, as well as those on which I have removed it.
added 20 laptops to eventually replace 5 year old workstations.
BIM360 project
Arch, M, E, P etc files all load nicely
small structural model (100 megs) takes 30 minutes on laptop to load even if it was just loaded in the morning (so refreshing CACHE file not an issue)
same project will load in 5 minutes total on older workstations.
At first I was thinking this was a laptop specific issue (bad network driver, something) but thinking now it is a bad 23.1, 23.1.1, 23.1.1.1 update. (despite my best efforts, there is a mix of versions in the team).
