After trying to modify a window I can’t touch it its grey out It shows like is inside of the wall. It is very strange I never saw something like that. Thank you.
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
… hi @Anonymous
… could be two things
… maybe you have two walls in the same place?
… like some links from consultants , mep, structure….
… but based on your picture most probably will be phasing
… click on a window and change the phase
… try all options… usually there will be two or three…
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
I did not know that it has phasing. Thanks you. Now the windows are showing ok.
Where did you get that cutlery in the project?
Can I have all the families that you are using in the project?
Can I have the cutlery, everything? Please.
… hi @Anonymous
… some made by me
… but most of them are from places like revitcity.com
…. or manufacturers of everything … depends what you need ... what you are looking for ...
… just google it … you can find plenty
... or try creating some... it will be fun
... and you will learn a lot
aRcHiTeCt.JM
REVIT EXPERT ELITE
