Hello, I need some help with a revit model I'm working on.
I created a mass and I filled it with personalized curtain wall panels, I closed and opened the model and now I cant select the mass, only the individual panels, and I can't do anithyng with them, I can't modify not even delete the mass.
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Check and see if the mass is turned off in the visibility/graphic override
If you want to toggle the massing on/off, go to massing & site and click on the show mass form and floors
