Can't make this window family width parameter work
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
jwallace708
727 Aufrufe, 5 Antworten
Can't adjust the family constraint for widths to be parametric. - Any help on this matter appreciated.
Family window attached.
5 ANTWORTEN 5
Nachricht 2 von 6
PaulusPresent_BB
als Antwort auf: jwallace708
Dear Wallace
I tested your family by changing the Width value to 2000 mm. This seems to work as the screenshots attached show.
I also took the liberty to put an EQ constrain on the reference planes that drive the geometry for the vertical window trims.
Does this answer your question?
Kind regards
Paulus
Nachricht 3 von 6
Ilic.Andrej
Why you say you cant adjust it? ...I just set one of the planes to define the origin and gave EQ dimensions for the ref planes in the middle....
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 4 von 6
jwallace708
als Antwort auf: Ilic.Andrej
Great job. - Is there a quick way off adjusting the 3 panels to be all equal & parametric? Panels in the middle are wider than side panels.
Nachricht 5 von 6
PaulusPresent_BB
Change the outer ends of the EQ constraint to the desired reference planes (aka the edges of the glass instead of the edge of the window) and reactivate the EQ constraint.
Nachricht 6 von 6
Ilic.Andrej
Here :leicht_lächelndes_Gesicht: Its fixed
Andrej Ilić
MSc Arch
