Can't make the curtain walls one piece
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
451 Aufrufe, 3 Antworten
For my facade design, I think of an continious facade consisting of circular and flat walls, but the walls are not one piece. When I try to join, they don't choose each other
3 ANTWORTEN 3
Nachricht 2 von 4
hmunsell
als Antwort auf: Anonymous
if you want it to be a continuous curtain wall use a  a Curtain System. Make Mass and use the Place on Face option.
Howard Munsell
Nachricht 3 von 4
martijn_pater
Perhaps consider that your facade would actually not be continuous as you say when built? When you draw the cw it will consist of segments anyway... Ofcourse you could group them if you want...
Nachricht 4 von 4
TripleM-Dev.net
You could always delete one of the 2 mullions.
The panel on the side of the deleted mullion will propably show a gap, depending how large a corner mullion would be a solution.
See if this helps: About Corner Mullion Types
- Michel
