i can`t lock wall core to anything by aligning in revit 2017 lt. Previous version doesn`t have that problem.
I can lock to wall faces, wall centerline but not to wall core. Please help....
I tried this on 2017 and works fine for me.
After selecting the aligned tool have you choose 'centre of core' from the options bar?
Hope this helps.
Hello, have you use the TAB to select the core wall. Thanks
An Autodesk person (Ryan) replied in a similar thread at RFO that he can reproduce this missing padlock. The issue is with Wall Core Centerline, no padlock appears. It works for the other Location Line choices.
Steve Stafford
We are having the same problem... no padlock in the centre. Have you got it sorted yet?
Cheers!
There is the answer - problem fixed:
