I keep on getting the error message "The shared parameter "a45a0050-2a39-4b29-bb1f-1b1430c9954d" cannot be added with name "EAN code" and type "URL" because it conflicts with the existing name "EAN code" and type "Text"", but I can't seem to fix this problem. The file is attached.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
The family you are loading has a shared parameter named EAN Code that is of the type URL. The project your are loading it into has a shared parameter that Is also named EAN Code, but is of the type TEXT. For some reason they both have the identical GUID.
Troubleshooting is a little tricky. I'd need more information to advise you. But the quick fix is to delete the EAN Code Parameter in the family you are trying to load, and create a new parameter to replace it.
Are you even concerned with reporting EAN Code? Doesn't sound like it. Just use the fix I suggested above.
