Can't Join Geometry
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
dm0144
576 Aufrufe, 1 Antwort
Can't Join Geometry
Hello everyone
Is there a reason why I cant join the wall betheath the slab with the slab itself?
ii constantly get the error message on the side.
1 ANTWORT 1
Nachricht 2 von 2
RDAOU
als Antwort auf: dm0144
@dm0144
When you want to work with Joined Geometry you do not use Unlocked Layers..
  1. Edit Group
  2. Edit wall type
  3. Re-Lock finish layer
  4. Join Geometry
  5. Stretch up
  6. Finish Group
If you are using the same wall type elsewhere and you need it to be unlocked, then you will need to duplicate and use a different wall type
