I'm somewhat of a newbie, but over 30 yrs. in AutoCAD. Anyway, I'm at wit's end trying to delete an object (see s/c). I modeled a rigid frame in 3D solids in AutoCAD to insert into my Revit model. They are successfully in-place under the front roof -- no problem. There is however, this frame I absolutely cannot highlight to delete, sitting on top of a wall of the rear building (in red). Tried all levels, all views and nothing. Help would be appreciated. Close-up shows a green line on a vert. element of it, and a turquoise line along the top beam edge.
After more thought, this seems to be a remnant of an earlier attempt at inserting another file out of AutoCAD, which was a frame made up of polyface meshes. I didn't realize it actually inserted, thus the reverting to modeling the same frame in 3D solids. So, it appears I have both now, and the mesh insertion refuses to leave. -- TIA Larry
Gelöst! Gehe zur Lösung
Gelöst von cbcarch. Gehe zur Lösung
Select one of the frames that you CAN select, the right-click, and choose Select All Instances in Project.
Then look at the lower right corner of your screen, this will tell you how many are selected.
Then, using the "sunglasses" tool at the bottom of the screen, while they are still selected--choose Isolate Element.
This will show only the bent frames in your view.
You should now be able to see / select the one you need to delete.
( Hint--you will find it better to model these types of elements in Revit, instead of importing/linking them from Acad.)
Some tips -
1) Go to Wireframe view
2) Hide objects that get in the way
3) Tab>>Click to cycle between overlapping objects
4) Set selection options as such -
or
Could the frame geometry somehow be in a design option? Elements in a design option will become "unselectable" like this.
Hmm..........perhaps it is a proxygraphics issue with the native Acad file?
Also, was the mesh cad dwg inserted into a Family? or inserted/linked directly into the model/revit project?
Try turning on "Imports in Families" under Visibility/Graphics>Imported Categories
Also, see if there is such a Family in the Project Browser, and if so, delete it from there.
