Can´t group railing TAG?
2 ANTWORTEN 2
Nachricht 1 von 3
VicBerg
393 Aufrufe, 2 Antworten
I can´t find a way to group railing TAG.
I use railing tags and get the message "None of the selected elements can be grouped. The elements may already be grouped or may be element types which are not allowed for grouping.".
Does anyone know a solution to this?
With king regards, Victor
Tags (2)
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: VicBerg
@VicBerg
The tags for railing can be added as an Attached detail group only. You cannot group them separately
Otherwise simply "Tag All'" the railing after grouping.
Nachricht 3 von 3
VicBerg
als Antwort auf: RDAOU
Thank you, that was another way to create attached detail group. Usually Revit created an attached detail group when trying to group taggs on components that are already in a group.  But with railing tags this dosnt work but your method did work. The other od thing or problem is that when I hide the attached detail group with railing tags, the group is deleted.
