Can't get window panel to "grey out" in cut view
1 ANTWORT 1
Nachricht 1 von 2
hallumE5UZD
176 Aufrufe, 1 Antwort
Hello All,
I have 2 window families I've created, both with their own hosted window panels. However one works fine, cuts correctly when loaded into a project, and correctly "greys out" the window panel in plan view. The other however does none of this.
I'm at a loss as to what I could be doing wrong.
I've tried to cross check both window families and the window panels within them, and all the settings seem the same, with different results.
If anyone could shed some light on this issue it's a mystery that's extremely frustrating .
Beschriftungen (4)
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: hallumE5UZD
Edit the Material and Remove the Surface Pattern.
