Can't find reference plane
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
emmanuelbee
4172 Aufrufe, 11 Antworten
Just a general question; sometimes when you create a workplane and then later on want to place something on that workplane, that work plane is never in the list of workplanes that you can't select in the dialogue box that comes up.
why is that?
its difficult to explain what i mean but i hope someone understands
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: emmanuelbee
Nachricht 3 von 12
Always label the reference planes you created.
Nachricht 4 von 12
emmanuelbee
als Antwort auf: ToanDN
Even if I've named it, sometimes its still not in the list
Nachricht 5 von 12
How are you setting the Work Plane?  Using "Set" tool?
Are you sure that you didn't delete the RP? Check the properties of the element you placed on it. Does it say "not associated"?
Nachricht 6 von 12
emmanuelbee
als Antwort auf: barthbradley
it normally happens when i draw something on a work plane and i want to change the work plane that i drew it on so i click on 'edit work plane' to place it on the named reference plane that i created and that reference plane is never on the list.
Nachricht 7 von 12
Yes. I can replicate that behavior.
Is the element "Non Associated"?
Nachricht 8 von 12
If you use Edit Work Plane then you are limited to the reference planes parallel to the original plane.  Use Pick New instead then you will be able to select the ones not parallel to the original as well.
Nachricht 9 von 12
Nachricht 10 von 12
Nachricht 11 von 12
Nachricht 12 von 12
rungerer
I had a similar problem. I am trying to change the plane for a series of beams to get them to slope. But when I select "Pick New" no drop down menu appears. How can I get the drop down menu back?
