I have REVIT 2022 and when I follow the default path for templates in program files>autodesk>rvt 2022 I can't find the template file? Even after I downloaded the UK library content, I can't find the templates. Can someone please guide me to where I can find and download the English metric default template, please?
try this LINK and see if helps. thanks
@Anonymous
You say you downloaded the UK library...did you install it after download?
In the meantime and till you find it, you can use the load family from the cloud
check here
@Anonymous
If you have installed to the default path then
Project Templates would be here
C:\ProgramData\Autodesk\RVT 2022\Templates
Family Templates
C:\ProgramData\Autodesk\RVT 2022\Family Templates
Otherwise, and if you installed to a different path than the default,
