We have in a large project a load of skirting that has been created using the Sweep command. Previously we have been able to select the sweep which selects everything in the view that is the sweep, then click on the path which turns pink, which allows us to change the sweep path. Today the sweep when selected first is highlighted blue and we get no options to click such as edit sketch path. I've attached an image of what we are getting.
Any idea why this has happened?
Try to use railing with skirting -profile and no baluster . It is more easier for modification and calculating
Model in place sweep. Thing is the person who started the project has left the company and it was set up as a shared model. I have gone back to a previous shared model and can edit the sweep like normal. Weirdly I have opened on my pc the latest shared version and can edit the file. The initial problem was on a different PC so not really sure why we had the problem. At least we can now edit it. Must have been a bug!
The computer that cannot edit the sweep may have Revit LT instead of Revit.
