Can't display floors on sturctural floor plan
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Lucasmanya2809
157 Aufrufe, 3 Antworten
I'm having trouble viewing some structural elements in their corresponding view (structural floor plan). I checked the floors as structural, and I have them checked on in visibility and graphics. I adjusted the view range, hidden line, and hidden object, but nothing worked. I can view them only on Level 2 but not on the other levels, even though they have the same properties. Any advice helps.
Lucasmanya2809_0-1733590588010.pngLucasmanya2809_1-1733590608780.pngLucasmanya2809_2-1733590758237.png
3 ANTWORTEN 3
Nachricht 2 von 4
rahid_mullas
als Antwort auf: Lucasmanya2809
Go to reveal hidden elements option by pressing RH. Open the view where your floor is visible. Come back in the view where it isn't visible if u see u hide option. Unhide it. Or else check the workset. If not check the view range settings. Check the view range of the plan where the floors are visible and apply the same where it isn't visible. If not then check the phases mode. If not then delete the view and create a new floor plan.
Nachricht 3 von 4
rahid_mullas
Accept the solution if it's done. Thank you
Nachricht 4 von 4
Lucasmanya2809
als Antwort auf: rahid_mullas
Tried all of that and didn't work. Did a bit more of searching and it was an issue with the filters. Just had to remove all of them
