Can't delete or modify existing elements in a revit model!
4 ANTWORTEN 4
Nachricht 1 von 5
ahirani24
306 Aufrufe, 4 Antworten
Hi All!
I'm unable to edit or delete existing elements in a model (I can't change existing pipe lengths, cabinet locations or even delete pipes). But I can place new elements and I can modify those elements. Would you know why this is happening? It might be something minor.. But still
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: ahirani24
Can't how?  You can't select them to delete?  You can select them to delete but nothing happens when delete?
Nachricht 3 von 5
RDAOU
@ahirani24
Does Revit pop any prompts when you try to edit or delete? such as elements being owned by someone else
Or are the option to delete and/or edit parameters grayed out such as when elements are in a Linked model (not the main model)
Nachricht 4 von 5
ahirani24
My bad it was an annotation model and so I couldn't do any edits in there.
Nachricht 5 von 5
RDAOU
@ahirani24
So to be clear,  the elements you were trying to edit were in a linked Model as mentioned in previous reply?
