Can't Delete Curtain Wall
Hello everyone,
I am new to Revit and am having some issues deleting a curtain wall.
I changed the wall type of a wall to "Exterior Glazing" but I would like to change it back to a generic 8" wall (I thought using a curtain wall would make it easier to create the facade I want, but I am going to attempt to create it with windows). However, now I can't select the wall to change it back to a generic 8" wall. Each individual panel is shown, but it is not shown as a wall and there is no way to select all of them as a wall. Please see the screenshots below.
Is there a way to change the individual panels back into a wall? Or to just delete them all so I can redraw a wall in their place?
Thank you!
Use your mouse crossing window to select a bunch of objects and use filter to get the curtain wall. Then change to other wall type.
Hi ToanDM,
When I do that it creates a series of small walls the same size as the curtain wall panels and I am still unable to delete them.
No. Filter out everything including the Curtail panels.  Only keep the Walls checked.  Sorry my previous instruction was not clear.
That worked! Thank you so much!
