Can't cut instance(s) of Parametric strip light out of its host.
8 ANTWORTEN 8
Nachricht 1 von 9
LiewYingJie
1003 Aufrufe, 8 Antworten
Hi, I have any issue to insert component which I had done in family file and load it onto my architectural model .I don't know why the Revit always mention about : 'Can't cut instance(s) of Parametric strip light out of its host and Instance is not cutting host.' Can someone help .
8 ANTWORTEN 8
Nachricht 2 von 9
XXalessio.amodioXX
als Antwort auf: LiewYingJie
First you should tell if your component (I assume Generic Model) is face based, roof base or wall based
Nachricht 3 von 9
this?
Your Void is not intersecting the Host. Probably not constrained properly.  Post the Family here.
Nachricht 4 von 9
LiewYingJie
als Antwort auf: XXalessio.amodioXX
is  roof base
Nachricht 5 von 9
LiewYingJie
als Antwort auf: barthbradley
it is customize , it is not load from the family file
Nachricht 6 von 9
XXalessio.amodioXX
I guess your family has a Void. Try to extend the void (In thickness) Sometimes the family is not cutting geometry beacuse the roof thicknes is too big.
Ps Good idea would be to share the family
Nachricht 7 von 9
LiewYingJie
ok thank you
Nachricht 8 von 9
Are you saying that the Light Fixture was modeled as an In-Place Modeled Component -- not a Loadable Family?  If so, then you have an UNATTACHED VOID in the Family. You need to cut something with the Void inside the Modeling environment or in the Project environment BEFORE closing out of the Modeling Session.
Nachricht 9 von 9
Is this the Error you are seeing?  It means the Void in the In=Place Family is not "attached" (e.g. cutting anything). You need to cut something with it - either inside the family or inside the Project - before you can close out of editing mode.
