Can't Cut Geometry With Void
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
dm0144
710 Aufrufe, 5 Antworten
Hello everyone
When I try to cut a floor element with a void modeled within a door family, I cget an error measge, saying that the wall can not be cut with that particular door instance, thus the door gets deleted.
Any help?
5 ANTWORTEN 5
Nachricht 2 von 6
kadmonkee
als Antwort auf: dm0144
do you have overlapping walls? the image looks like there are 2 different walls and a door
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 3 von 6
dm0144
als Antwort auf: kadmonkee
@kadmonkee check revit model please.
Nachricht 4 von 6
kadmonkee
unfortunately I am not running the latest version to open your file
thank you
Nachricht 5 von 6
RDAOU
@dm0144
Do the following
  1. Edit door family
  2. Delete the Opening Cut element and replace with a Void extrusion
  3. Cut wall with the new void extrusion
  4. Cut wall with the void from the floor box
  5. Load into Project
    • Use Cut Geometry to cut floor with the door
Alternatively...
  • Model the Floor Box Void as a Nested Shared Generic Model
  • When cutting in the project, use Tab to select just the nested shared generic void extrusion
See GIF below...
Nachricht 6 von 6
dm0144
als Antwort auf: RDAOU
@RDAOU Thanks!
