Can't create this kind of element in this view in the current mode.
Hello all, I'm trying to load  a parametric revolving door into my model on ground floor plan view.  I receive the following notification 'Can't create this kind of element in this view in the current mode.' I've successfully loaded a different revolving door so can't see what the issue is.
zeulrick
Try placing the door in a 3d view with the reference plane set to the level you want to place it. My guess is the family is not a door family but something else entirely.
It maybe a curtain wall door, which cannot be placed directly in the model. To place it, change a curtain panel type to that door type.
ennujozlagam
are you trying to place your door in curtain wall or wall. share here your door family so we can check. thanks
Inserting as a curtain panel works, thanks all
What "mode" are you in?
