I am creating a roof over a building, its two sides are kind of mirrored. I struggled a lot with the mysterious error "cant create roof". Eventually I gave up and created a simple roof by only giving slope to all horizontal lines and no slope to the vertical ones. Then I started adding slopes to the vertical lines one by one. That's how I got here. I can define slopes on one side, but not on the other side, which is exactly mirrored.
In this case, look at the top left part of the building and the bottom left part of the building. Notice how the roof on both parts is different cos I get that error when I try to create the same roof in the bottom left part.
Any tips?
If you're trying to make the roof footprint follow all of the exterior walls with hips on all sides, the geometry just won't work. I created a roof without the offset on the plan north side of the building so you can see. That offset just won't work with hips on all sides (see pic).
