Can't create pdf
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
2526 Aufrufe, 8 Antworten
Can't create pdf
Good morning. I cannot create pdf from Revit. I downloaded Bluebeam as I was thinking it was a PDF software issue.
the printer dialog box opens but when I click on "Select" nothing happens.
any suggestions please?
thank you
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Anonymous
Have you tried setting path (Name) first?
...seems to be a lot of threads related to this.  Check out this discussion:
https://forums.autodesk.com/t5/revit-architecture-forum/can-t-access-print-range-selected-views-shee...
Nachricht 3 von 9
husamcivil
als Antwort auf: barthbradley
Install PDF creator software its free  and after page setting select PDF creator instead of printer name
Nachricht 4 von 9
Avaris.
In some cases it is just a matter of using the shortcut crtl+p instead of the actual button. Adobe PDF print will nearly in all cases when going for the shortcut method.
Nachricht 5 von 9
als Antwort auf: Avaris.
I noticed that Print to File is not grayed out, leading me to believe the PDF converter is being improperly recognized as a peripheral device.  I wonder if the converter is installed properly -- or if maybe checking that box would resolve issue.
Nachricht 6 von 9
als Antwort auf: husamcivil
Thank you for your response. I downloaded the software and it didn’t work.
🥺:denkendes_Gesicht:🤭:lügendes_Gesicht::enttäuschtes_Gesicht::denkendes_Gesicht:
Pedro
Nachricht 7 von 9
I don't understand your question: "'Have you tried setting path (Name) first? "
I checked out the link you provided me and it doesn't help either.
thnk for your time
Nachricht 8 von 9
I checked out the link you sent me and I found the solution
THANK YOUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
Nachricht 9 von 9
THANK YOU, SOLVED, HAPPY HOLIDAYS
