Can't create new families
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
elias_munoz_neyra
734 Aufrufe, 3 Antworten
Greetings,
Lately I have been having problems with Revit every time I attempted to create a new .rfa archive. It appears to be loading and then the program freezes and won't open anything, as shown in the attached picture. What can I do?
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: elias_munoz_neyra
@elias_munoz_neyra hello, what version of Revit do you have? have you try to install latest updates and service packs from autodesk and update graphics card driver to the latest. try to untick use hardware acceleration and see if helps. thanks
Nachricht 3 von 4
elias_munoz_neyra
als Antwort auf: ennujozlagam
Thank you for you reply.
I have Revit 2016 with SP2 installed. Hardware accleration was unticked. As for GPU, I have a Asus Strix GTX 1060. Haven't given me any problem so far. It is updated with the latest patch.
As for now, I uninstalled the software to see if it works. SO far When I attempt to install, I receive a notification pointing out a problem with Microsoft Visual C++ 2005
Greetings
Nachricht 4 von 4
Update:
I ended up formatting my PC. Problem is solved
