Can`t copy parts
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
4414 Aufrufe, 5 Antworten
Can`t copy parts
Hello!
I have multiple walls divieded into panels using the parts tool. What i need is to copy those walls for the others levels of the building. When I try to do that, the error is the following:
"Some elements were not copied.
Parts cannot be copied without their original Element. To copy Parts, select the original."
Thank you!
5 ANTWORTEN 5
Nachricht 2 von 6
bin
als Antwort auf: Anonymous
Can you copy the wall instead of the parts?
Can you copy the wall together with the parts?
Nachricht 3 von 6
constantin.stroescu
When you are going to copy the Wall that has Parts , first uncheck Parts visibility from VGO , copy the wall and then check back the Parts - the copied Wall will have the Parts copied too..
Constantin Stroescu
Nachricht 4 von 6
als Antwort auf: constantin.stroescu
Thank you very much!
Nachricht 5 von 6
mairh_tsek
I have the same issue. I have a linked model, and I want to copy a mass in my project. When I try to copy it , I have the error ' Can't copy part of element ' . In the V/G I have unchecked the Parts and in the view properties I have 'show original'..
Do you have any solution/idea?
Thank you in advance !
Tags (1)
Nachricht 6 von 6
constantin.stroescu
als Antwort auf: mairh_tsek
I think it's a misunderstood here....That's not about Parts as separate layers of a Walls,Floors or Roofs...
The message is about some components (parts) of a Mass that Revit can not be processed...
Constantin Stroescu
