In Revit 2018 I have a project and I can't seem to click on most conduits in a 3D view. I can, however, make a crossing window and select objects just not a single pick. What am I missing? Everything works fine in plan views, ect.
Makes sure that these are set right
Do you have Design Options? That may also make some objects non-selectable.
Can you share a file?
I am not able to share this file. One thing that I've found is that in wireframe mode it has no problems.
Hi @Anonymous
It's been a while and I'm checking back to see if there is any progress.
If you can share a screenshot with us, it will help us troubleshoot better.
Looking forward to your reply update.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
