Can´t change the patern of the balusters
roberto.AconSegura
roberto.AconSegura
Hello everybody,
We have a problem when trying to change the visibility in a view of the balusters patern. If we change the line it works.
The same happens when cutting in plan.
It does not work  with filters either.
We have tried with other subcategories and it worked (in the example with a gutter, subcategory of roof)
Thanks in advance,
Roberto
Use a Filter...
roberto.AconSegura
Thanks in advance for your reply @barthbradley
I would like to change the visibility only in the balusters, not also the top rail. Do you think there is a way?
You could nest a shared generic model family in the baluster family, associate parameters and geometry, and create a filter to override it in the project's views.
You could get there with a combination of filters...
...you need to make the Baluster Family Shared first.
