can't change scale of the drawings, only in 2 plans
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
jorgedacunha60
2788 Aufrufe, 2 Antworten
Hi there,
I have a little problem, tried to figure out, but I couldn't. I have 4 plans as follow: basement floor plan, ground floor plan, 2nd floor plan and roof plan,
I can change scale and and graphic display on 2nd floor plan and roof plan, but my basement floor plan and ground floor plan, scale and graphic display is greyed out, how can I fix this little problem.
Thanks, in advance,
George Da Cunha
2 ANTWORTEN 2
Nachricht 2 von 3
maybe you have a View Template allocated to those Views (Properties>Identity Data> View Template)
In this case, you have to change View Template to none or Exclude View Scale from it ( or modify view scale in Template)
Constantin Stroescu
Nachricht 3 von 3
Thank you for the hint,
George Da Cunha
