Can't change mass parameter after create the shape
I'll attach the mass family i'm modeling, so you can make a try. My problem is that i can change all parameters as the mass is made only of lines, but after creating the solid shape i can no longer change anything. Maybe i'm doing something wrong with the restraints/bonds.
Try this one.  I flex'ed the parameters and the form changed.
That's great the *(1) is what i was looking for! Thank you very much!
This is my pure personal opinion and I don't have any data to back it up.  But if I were you I would generate 3 profiles from the points, then create the final form from the profiles.
