Can't change Elevations
3 ANTWORTEN 3
Nachricht 1 von 4
1746 Aufrufe, 3 Antworten
Hi Guys,
I am working with revit 2017 arch n structure model... in project I have first floor on 14' and second floor level 29'6"
and I want to change elevation for first floor level 13' and second floor level 28'10"..
when i am changing first floor level 13' at the same time second level elvation level also changed automatically as 29'.
I want to change elevation level individually but I can't... may be some error in this file..
how to change ? Please help me....
This error only with one file... other files working fine..
Thank you.
3 ANTWORTEN 3
Nachricht 2 von 4
jsanders
als Antwort auf: Anonymous
Are you changing the floor level in an elevation view ?
__________________________________________________________________________
ヽ༼ຈل͜ຈ༽ノ Onward still he goes, Yet ne'er looks forward further than his nose ヽ༼ຈل͜ຈ༽ノ
Nachricht 3 von 4
I can think of many explanations. First: Hidden Constraints.  Reveal Hidden Constraints and see if there are any.
Nachricht 4 von 4
The levels are constrained together with a dimension string. Click on the Reveal Constraints down the bottom bar (a dimension with a padlock) to see the constraint then you can free the levels from it. Then you can change one level without affecting the others.
