Can't change elevation mark pointer.
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
2993 Aufrufe, 3 Antworten
Version : 2018
Windows 7
Graphics: base
I managed to duplicate the body for interior elevation markers, simple enough change and the family shows up under elevation tag in its properties. What I cant manage to figure out is how to change the pointer to my custom round one. I thought maybe it would be in the family of the body. But I couldn't find anything there.
Check out my screenshot.
Tags (1)
3 ANTWORTEN 3
Nachricht 2 von 4
GustavoUbriaco
als Antwort auf: Anonymous
I attached my steps to change the callout elevation shape if you've already the family created only steps 4 and 5 then insert the family to your project.
1 Identify the name of the elevation mark body then search in PB families then select and right click then edit
2 In the editor select the callout head and then select edit family
3 edit the filled region
4 then load to the elevation head family then save the family with a new name then load to your project then select the elevation duplicate if you like and change the elevation tag choose the new one loaded
5 then ok, I hope this will be helpful
Gustavo Ubriaco Contreras
Nachricht 3 von 4
You need to do this through Additional Settings.
Nachricht 4 von 4
als Antwort auf: GustavoUbriaco
Thank you! Idk why I couldn't just edit it in the family.
