I made a custom roof with a mass and reference lines. However when I try to attach the walls to the roof it doesn't work for two of the walls and gives an error message. I don't know why and my first draft of the roof which almost had the same shape could connect to all of the walls. The file is attached, see below. Thanks!
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
You just need to select the right roof on top of the wall … they all attach fine see screencast https://autode.sk/2urcdqO
Haven't looked at the file, but I've encountered something like that before when the join with roof angle was too steep I think. I just used edit sketch&join on those walls then.
@Anonymous
Check the screencast above...they all attach fine
Having another look at the Revit file, the mass you have created is slightly off axis. You need to fix the alignment of the roof for the walls to join properly.
Waiting for the screencast to upload; here is what I did:
Here is the screencast LINK https://autode.sk/31yYhXO
Ah I see! I'll try it myself! Just got notified that the house has to be resized so I have to redo everything... Thanks for all the support!
Nice, I probably had that same issue with the alignment then that time...
The walls in my model (much simpler roof) do not behave the way your screen cast shows. If my wall is entirely under one section of roof, they attach just fine, but if the wall passes under a hip, or valley, or in this case a pitch break, it just gives the awful orange "Can't keep wall and roof joined" error. I can see in your screen cast that you extend the wall to one roof, and then extend the wall again to the next section of roof, but my model won't attach any portion of the wall to either roof. This model was imported into a Generic Component from a Sketchup file.
