can't add a bump map to material
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
1903 Aufrufe, 1 Antwort
i'm trying to add a bump map to a material someone else created and the option is not appearing in the appearance tab of the material editor. I can edit other values that are in the material but bump is simply not present.
1 ANTWORT 1
Nachricht 2 von 2
L.Maas
als Antwort auf: Anonymous
You have to replace the appearance asset with a different type. Different appearance asset types have different fields.
For example the appearance asset of type Generic has a bump map fields available
Louis
Please mention Revit version, especially when uploading Revit files.
