Can't access print range 'selected views/sheets' and setup with print?
22 ANTWORTEN 22
Nachricht 1 von 23
14616 Aufrufe, 22 Antworten
Hope someone can assist with this issue.
I click the icon 'select' which normally brings up another window where I select which views/sheets to print but nothing happens. Similar issue with setup as i click the icon and nothing happens. I was in the middle of printing to pdf (4 sheets as individual pdf's), it created the first two fine then stopped and I haven't been able to print since on any Revit project or family.
Can someone suggest a solution?
I've checked other programs and I can print to pdf and desktop printer, only getting this issue with Revit.
22 ANTWORTEN 22
Nachricht 2 von 23
L.Maas
als Antwort auf: Anonymous
Not direct solutions. You can start with the common ones.
-Restart Revit.
-Restart your computer.
-Check for updates (Revit, OS, Printer Driver)
-Look at your journals and see if something is reported. To do this
  • Close and Reopen
  • Perform the actions that creates the problem
  • Check and/or upload the last journal file.  Journal files are in %LOCALAPPDATA%\Autodesk\Revit\<Product name and release>\Journals
-Reinstall printer drivers
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 23
draftorb
In Windows, go to printers, and then change the default printer. I had a very similar problem, and this solved it for me.
Nachricht 4 von 23
ennujozlagam
@Anonymous hello, you can try this "Uninstall (Windows 7) KB 3177725 and (Windows 10) KB 3176493" see if this helps. thanks
Nachricht 5 von 23
ronsarlo
als Antwort auf: draftorb
Revit 2017, @draftorb's suggestion worked for me as well.
Thank you sir!
Nachricht 6 von 23
als Antwort auf: ronsarlo
A bug with Revit which has been allowed to persist for now (at least) 3 years.
When printing multiple .pdf's, Revit's communication with the .pdf printer (and this happens with multiple .pdf printers, including native Windows) gets stuck somehow, leaving the print dialogue unusable.
The fix is to either switch printer manually (as suggested in this thread), or to simply "print in the blind", by changing printer in Revit and clicking ok, after which the next print dialogue will work again.
Nachricht 7 von 23
It is an odd issue, since it initially appears that the popup windows are not showing in window, but they are never created. In addition to the listed solutions, I have also just found this can be remedied by clicking the checkbox for "Print to File" (one of the few print dialog options that should still work). Click "OK". Nothing will be printed, to file or otherwise, but it will restore proper function to printing.
Nachricht 8 von 23
Thank you sooo!! It worked for me!!
Nachricht 9 von 23
jens_lathouwers
Using another pdf writer might help as well. As most standard things in windows *edge*, the windows to pdf writer causes problems for me. I now installed cutePDF and now it works again. So it definitely has something to do with the windows to pdf feature.
Nachricht 10 von 23
aquevedo
Thanks changing the default printer worked for me :leicht_lächelndes_Gesicht:
Nachricht 11 von 23
It's Worked for me... changing default printer after start Revit....
Nachricht 12 von 23
jules
I can't believe clicking the print to file button has resolved this for me after multiple reinstalls, printer removals and work arounds!
Thankyou!
Nachricht 13 von 23
Yup, this is the solution here. That was so frustrating because I didnt want to download a PDF creator.
Nachricht 14 von 23
Actually this happened for unrecognized printers like Nitro or something... Cutepdf is best for revit
Nachricht 15 von 23
jules
"Print to file" is working but still needs to be done EVERY time I open
Revit.
Would love a permanent solution!
Nachricht 16 von 23
it's work, Thank you
Nachricht 17 von 23
ilkay_GENX
changing default printer worked for me too... thank you!
Nachricht 18 von 23
Changing the default printer worked, but I have to restart every time I want to print something. Is there a permanent solution?
Nachricht 19 von 23
Did you try my fix?
If your driver 'got stuck' in Revit's Print-universe, that might be the solution for you :leicht_lächelndes_Gesicht:
- Max
Nachricht 20 von 23
Cutepdf solved my problem
