Can't access Materials and Finishes tab trying to change curtain wall material
3 ANTWORTEN 3
Nachricht 1 von 4
3351 Aufrufe, 3 Antworten
I'm trying to change the color of the glass of a an entire curtain wall. I've created the new material that I want to apply to the curtain wall, I've duplicated the curtain wall that I wish to edit, but when I click "edit type" I am unable to change the material to the glass type that I created. The Materials and Finishes tab is grayed out. I'm sure I'm probably doing it wrong, but I haven't come across any other ways to do it so far.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
A curtain wall has no material.  You need to assign the materials to the curtain wall panel types and the curtain wall mullion types that being used for the curtain wall.
Nachricht 3 von 4
als Antwort auf: ToanDN
thanks, how do I do that?
Nachricht 4 von 4
I figured out how to do it, but I've come across a different issue... None of my panels are pinned, but my ability to select them is almost nonexistent. This is likely the reason I had so much trouble changing the material of the panels. 95% percent of them are unselectable, and for some reason, there are a few scattered randomly throughout my project that I AM able to select. I'll have a section of curtain wall with grids and such, but I can only select one, maybe two panels if I'm lucky. This is an issue, as I am unable to add doors and other features where I need them, because I can't select the panels that I want to. Do you have any idea why my panels would be behaving this way?
