Can someone please help me to create a circular curtain wall
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
391 Aufrufe, 4 Antworten
As per the attached - yellow outline of where i'd like to place (the overlay is a CAD file)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Is that circular wall one piece of glass or does it have some mullions?  If it has mullions with straight sheets of glass between, then just add grid lines to the circular wall that you drew and they will start to assume the angles.
Nachricht 3 von 5
ennujozlagam
you can try this. you can adjust setting thru edit type and see if helps. thanks
Nachricht 4 von 5
als Antwort auf: ennujozlagam
Thanks mate - I'll change to a solution but one more q- how do i make a screen cast?
Nachricht 5 von 5
ennujozlagam
hello, you can download from Autodesk Screencast and install. thanks
