Can someone help me in convert an rfa file to DWG or IPT or STEP
Thanks in advance.
Gelöst! Gehe zur Lösung
Gelöst von BIM.Consultant. Gehe zur Lösung
Simple open the family in a 3D view then export is as DWG file. Please find it attached.
Go to a 3d view and then:
REVIT (Icon) > Export > CAD Formats > Choose your format
Depending on the format, a window will appear. Choose the views you want (the view {3D export the modelling) and than choose the path on your computer
You just have to do the same, just open the family and follow the same steps.
Hi Thanks for your feedback but I don't have Revit installed.
I guess the only way is through Revit?
Regards
Marco
@Anonymous wrote:You just have to do the same, just open the family and follow the same steps.
I don't know about other software that opens rfa files to convert them. So the only way I know is through Revit.
Thank you for your feedback. I confirmed that I need to use Revit or try to get those drawings already converted.
Marco
