AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
can see drawing , can't select
5 ANTWORTEN 5
Nachricht 1 von 6
yoiyoi
237 Aufrufe, 5 Antworten
i've linked/imported an  dwg file into revit and can see it as background in my pln view but can't select it
what might i be doing wrong?
thx
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: yoiyoi
Enable Select Links.  Make sure no red X is over this icon.
Nachricht 3 von 6
GustavoUbriaco
als Antwort auf: ToanDN
To accomplish also the next two elements in case are underlay or pinned doesn't it?
Gustavo Ubriaco Contreras
Nachricht 4 von 6
Can't select it how?  By hovering over it and not the bounding box? If the bounding box ain't visible in the view, try clicking on it.
Nachricht 5 von 6
yoiyoi
als Antwort auf: barthbradley
thanks guys, it was a view range and visual style issue
Nachricht 6 von 6
Sorry but something doesn't sound right. If you can SEE and cannot SELECT the DWG like you said initially then the  issue is not view range or visual style.
In Foren verƶffentlichen
