Hi everyone,
Have a slight issue here. I downloaded a family from bimlibrary that I want to incorporate into my job package. However, when I insert that family into my family, it appears only in 3d view. I does no appear in Front, Side or Plan view. Any suggestions why? In View settings it is set to appear in all views, so no idea why..
Gelöst! Gehe zur Lösung
Gelöst von hossamnet0semo. Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
Select the object. Look in its Properties.
Sounds like visibility states aren't set to show in those views. Go to family and check out visibility states for each of the geometrys that are defined in the family then reload into project.
