can not open the Revit file
29 ANTWORTEN 29
Nachricht 1 von 30
Yara-architecture
2265 Aufrufe, 29 Antworten
hello, how to recover file when Revit gave me this message (can not open the file there is missing many elements), how to solve that, thank you in advance.
29 ANTWORTEN 29
Nachricht 2 von 30
ennujozlagam
als Antwort auf: Yara-architecture
have you try to tick audit before opening the file and see if helps. thanks
Nachricht 3 von 30
Yara-architecture
als Antwort auf: ennujozlagam
hello, what do you mean by that (tick audit)?
thank you for the answer
Nachricht 4 von 30
martijn_pater
See attached.
Nachricht 5 von 30
Yara-architecture
als Antwort auf: martijn_pater
hello, gave me this message, and that what does do for the file?
Nachricht 6 von 30
ennujozlagam
did you upgrade your file in a higher version? open your revit program first then open the file. yes that is correct tick the audit box before opening the file. thanks
Nachricht 7 von 30
Yara-architecture
i did what you had mentioned, but it gave me this message( that I attached), so I choose yes?
thank you
Nachricht 8 von 30
ennujozlagam
okay, i hope your issues will be fixed and try to install latest updates from autodesk. thanks
Nachricht 9 von 30
Yara-architecture
sorry, you didn't answer my last question., if i need to choose yes?
Nachricht 10 von 30
ennujozlagam
yes. but copy the file into another folder just incase something happen wrong. thanks
Nachricht 11 von 30
Yara-architecture
ok, i will, thank you so much i will let you know if the problem solved.
thank you
Nachricht 12 von 30
Yara-architecture
I tried that, so after chosen yes there is nothing happens, it should give me a new message or what?
thank you
Nachricht 13 von 30
ennujozlagam
can you share your file so we can check? thanks
Nachricht 14 von 30
apurba
Have you downloaded the file from internet? the file may be corrupted due to not downloaded correctly.
please tic the Audit option present in the open file menu ( Left side bellow as shown on attachment)
Hope, this will help
Apurba Baruah
i7, 16GB,1TB
Nachricht 15 von 30
ennujozlagam
als Antwort auf: apurba
dude, you are not reading? thanks
Nachricht 16 von 30
Corsten.Au
Hi
If the file is corrupt then its difficulty to recover .
You may try these
1. Audit the file while opening.
2. if its a central file then try DETACH and open
   ( while opening, go to the WORKSETs, and uncheck all )
3. You may try opening the " Backup " files ( Example SAMPLE.001.rvt ) etc
4. If there are LINKED Revit files then Revit tries to load linked Revit files, you can change the folder name where links are saved so that while opening the file they don't load by default.
5. Learn how to recover the file from, Restore the file..its in Collaborate-Restore Backup.
Best luck
Corsten
Building Designer
Nachricht 17 von 30
Yara-architecture
 hello, i can not attach the file, thank you for the help
Nachricht 18 von 30
Yara-architecture
no itis not from the internet, i did what did you say but nothing happens.
Nachricht 19 von 30
Yara-architecture
sorry, i was busy just can read your answer and replied.
thanks
Nachricht 20 von 30
Yara-architecture
als Antwort auf: Corsten.Au
i will try that.
