Whenever I import a (2D) CAD file into Revit the following error occurs; None of the created elements are visible in Floor Plan: Level 1 View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
What do I have to do?
Adjust the View Range.
Raise Cut Plane and set other values to Unlimited. See it now? If not, maybe the Category is Hidden.
You might be placing it on the wrong level - one that is not within the View Range.
