Can not export IFC file from Revit
2 ANTWORTEN 2
Nachricht 1 von 3
r.naagar
425 Aufrufe, 2 Antworten
I am currently working on a Revit project and I need to export the IFC file. It gives me warnings that there is a problem with one of the handrail family. I've already tried deleting these families, purging the model, and also making the file size smaller, but I still cannot export IFC or the IFC generated is empty.
Also, the Revit file is 412 MB (which is not so huge),  and one of the last export which was empty was 835 MB. Can someone tell me about the possible solutions to this problem or what I am doing wrong?
(I am using Revit 2020.2)
2 ANTWORTEN 2
Nachricht 2 von 3
syman2000
als Antwort auf: r.naagar
Try using Revit to ArchiCAD IFC addon. I find their IFC export a bit better than the Out of the box Revit IFC
https://graphisoft.com/downloads/interoperability
Nachricht 3 von 3
ThierryEL
If the IFC file is 835 mb, it's probably not empty. There's probably and element really far from the rest of your project and that's why you can't see both of them in a viewer.
With Solibri Anywhere (free), you can open your IFC file and it should give you a warning if some elements are really far from the rest of you project.
