Can not edit roof footprint
4 ANTWORTEN 4
Nachricht 1 von 5
glkirk
1367 Aufrufe, 4 Antworten
A little while ago, I had to use Revit 20 without internet access. I noted that the "Error Reporting" was not working but everything seemed to work OK.
Not, a week later and on another project, the "Error Reporting" doen not work and I have been having a very hard editing walls and now can not edit the footprint on this roof.
Seems that I DL all the latest fixes from Auto desk.........
Does anyone have any thoughts?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: glkirk
Remove Infrawork addin.
Nachricht 3 von 5
glkirk
als Antwort auf: ToanDN
I believe you are right!
But, Im looking at the "fix", I am reluctant to try that.
I', wondering if there may be a better (or less troublesome) way of getting it fixed?
I wonder if I can call Autodesk?
Nachricht 4 von 5
That is the fix that Autodesk recommends.
Nachricht 5 von 5
glkirk
OK, So, As I didn't understand how to find the latest update, I thought I was going to have to go into the Administrative files and do stuff. I did not! want to do that.
Anyways, I finally found the little arrow on my desktop Autodesk dashboard that found the latest updates. There was the one I needed!
Updated and now all is well.
